IH 464 Hydraulic
Aubtiger77
New User
The 3 point hitch has worked since purchasing tractor.
the 3 or hitch wouldn't go down and hyd are humming like it doesn't bypass, which is heating up the oil. It jumped once and went down then when I raised it it stayed up unless I manually force it down inside inspection cover. Which stops humming until it is released and goes back up.
Hi, make sure draft control lever is fully forward. Next shut engine off a put 3pt level in down position, does the 3pt go down?
If not try standing on 3pt arms, does 3pt go down now?
Could be dirt in unloading valve or 3pt or draph control mechanism has become unhooked inside hydraulic housing.
JimB
