Can't get it started
dkawucha
New User
O.K. 8N friends.
I have a 1950 8n with the side mount diestributor. Sometime before I bought it it was converted to 12v. I am having major problems getting it started.
We had a lot of rain recently and the tractor has been outside. I went to start it, it started, ran rough for about 30 seconds and then died. I haven't been able to start it since. I have replaced the points, condenser (twice), coil and ballast resistor to no avail. The coil wire is good and I am getting fuel. I have also rebuilt the carb. When I pull a plug wire and crank iot, I get no spark. Any suggestions?
Clean the production coating off of the points. A match book abrasive is good, then a folded dollar bill. to assure they are clean. Jim
Thanks Jim. Did that already but no luck. I'm thinking it's something farther upstream. I'm getting no spark from the coil or the plugs.
If it is very damp out you could have condensation inside the distributor cap, I have heard that if you spray the inside with WD-40 and then wipe it out it can solve that problem. WD= water displacer.
Points dirty or wet will cause that. Pull the distributor cap off turn it on then open the points by hand wit ha stick etc so you do not get shocked. You should both hear and see a spark when you do that. If you do not the points are bad or need cleaned
Put a test light on the lead going to the points on the outside of the distributor. Ground the light lead. With the ignition on, crank the engine. if the light flashes, the points are working. if not, and the light stays on, the points are not closing, or the connection is open to the points. If it stays off, the points (or lead to the points) are closed, not opening, shorted to ground, or the lead where it passes through is shorted to ground.
If it flashes, the next check is to put the coil wire 1/4" away from the block (connected to the coil, not the cap) to see if it has fire at the coil. If it does it is in the cap/rotor. Jim
You didn't mention changing the distributor cap. Cracks can be hard to see. I would swap that and the rotor. If sparks going into the dizzy and not coming out, that could be your problem.
A lot of good advice here but I would start at the beginning at make sure there is voltage before the ignition switch and work my way down from there.
Be sure to report back with what the problem was when you find it. Troubleshoot one component at a time until you find the problem, otherwise you don't learn anything!
