in-too-deep
Good afternoon, all! We have a 24'x28' garage that
we'd like to remodel. It was built in the 80's out
of rough cut pine boards. Studs and rafters 2' o.c.
Soon to have a steel roof over plywood sheathing.
Insulated but no interior sheathing. 1/2 in plywood
walls outside. Has 2- 8 ft wide overhead doors on
one end. 9 ft ceilings. We would really like to
raise it 3ft to get 12 ft ceilings. How would you do
it? I have access to a couple big friggin I-beams.
Would you build a new 3 ft wall to put under the
bottom plate? Or would you take bottom plate off and
scab new stubs on to and under the existing? Also,
would two- 5000 lb forklifts pick the whole thing up
using the I -beams?
using the I -beams?
