Small Farmall Or International Tractor Identification
NoahV
New User
I just received a tractor from a friend of the family and need help identifying it. Thanks in advance.
YOu'll get a good response here, but you'll get an excellent response on the Farmall-IH forum.
That's a Farmall "A" with an exhaust lift system. The exhaust system isn't that common any more. Most of them were taken off and scrapped.
You have an A with part of the two way moldboard plow which was the A-187 model you also have shutters or at least the crank for opening and closing them looks lke the original 6v gen with cut-out on the charging system. It is a good piece to get cleaned up and running again dont junk anything as there are some great parts you could sell.
John, on that exhaust lift, I have never
seen that before. How does that work?
I have a 'cub'. Ed will.
A valve outboard of the manifold diverts engine exhaust into the lift cylinder, forcing it to behave somewhat like a hydraulic cylinder. Slow, hard on engine (valves) and a maintenance headache. Not one of their better ideas. Most I have seen were mounted vertically near radiator, and used cables & chains to lift implement.
