Te20 petrol pto jumps out
Te20fergus
New User
Hi all this is my 4th tea20 my other 3 when slashing with 4 foot slasher stop in thick grass this one the engaging lever bounces then pops out I've spoken local guy he suggested pto selector so I pulled pump n shaft out and u can see bout 2mm on each gear was bit rounded but didn't look bad enough to jump out so I also pulled ball n spring spun shaft 180 stretched spring and reassembled tractor still does same thing bearings looked fine so has anyone got any idea would be great for any advice
Never slashed with a tractor... but...
grab the pto shaft and see if it moves in and out. If it moves more than the thickness of a quarter, your rear bearing mount needs to be pulled and the locking circlip needs to be put back in. Sometimes the rear bearing housing is damaged and the groove will not hold the clip in place. also if the inner end of the shaft has twisted, it will unscrew it self and pop out, when loaded,, you will then need a new shaft.
I have shredded with a shredder,,officially,, a rotary cutter aka brush hog, and cut with a sickle bar, and have used a disc cutter, a mowco, disced and rennovated, plowed, mowed,baled, harvested,, but never slashed with a slasher... :D
