Indiana Ken
I have an electronic tach I would like to use on a single cylinder 4-stroke engine. My engine has a crank trigger and fires once each 360 degrees of crank rotation. The tach is for a single cylinder 4 stroke however, it appears to be calibrated for a spark every every 720 degrees of crank rotation.
The tach requires 12 volt power and takes a signal from the (-) terminal on the coil. It works fine except, it reads 2 times the RPM the engine is actually running.
Is there a device I can buy or a circuit I can make that will count to two then output one signal, such that the tach will read actual engine RPM?
