BANDITFARMER
After posting twice about rear tractor tires today I open the barn door to find my Long 900 sitting funny. WTFrig? The tire that was close to my 930 Case is flat! Not a little down no no no it's flatter than a flitter! And guess ware the valve stem is? You guessed it right on the bottom ware you cant get to it. So I guess tomorrow I will be doing some moving around to get the Case moved so I can get to the valve stem and get it pumped up. I should have know better to talk about rear tractor tires, Now I have a flat! Last pic see the little white spot at the bottom of the rim, That's the stem I cant get to. Bandit
