Ford 2110 4x4
Gmc@2006
New User
I recently purchased a ford 2110 4x4 compact tractor and the Oil pan has a leak. How do you remove the oil pan on this tractor the pan is formed around the front driveshaft. Looks like there should be a way to drop shaft and remove pan any ideas thanks
It seems to me that you have to split those tractors to get the drive shaft cover off. Other option is to remove the front axle and slide it away... but it's quite some time since I worked on one. I think the drive shaft itself will come off but the cover won't..
Rod
