37chief
- Location
- California
Seams no mater the problem some one here can help. Here is the problem with my 08 Ford Edge. I started out in drive this morning the car didn't shift to a higher gear. I went to N and back to D while driving in low it shifted to a higher gear. I shut it off and restarted the motor, it shifts normal now. This is the second time this has happened. The first time I took it to a shop, they couldn't find any codes, or problem. The car has 43,000 mi. The level is also ok. While at the shop I had them drain the and refill the transmission. since there is no pan, or filter to be checked or changed, that is all that could be none, without removing the tranny. Thanks for any help. Stan
