Hi everyone,
Been a while since I posted and in the meantime thanks to this forum, I have learned a lot. My backhoe has a roosa master pump and displayed classic failure. I removed the pump and replaced the disintegrated retainer ring, cleaned and re-assembled with new O-rings and installed on motor.My problem now is that it will not pump. Fuel gets to the pump, and will run out of the timing cover if I open it, but will just kind of dribble out of the injector ports.I thought that I had re-assemble correctly, but is there something obvious that I did not due that would cause this? Any thoughts would be welcome. Thanks, Gene
