JD 755 red rear lights?
This tractor has orange flashing warning lights on the top of the fenders--that's not what I'm asking about. What I want to know is what are the rectangular rear only facing lamps built into the fenders? Are the brake lights? Under what conditions should they be working? The manual I have makes no mention of them.
They are tail lights only not brake lights. I know none of the US sold JD compact utilities have factory brake lights of that era. The European models had brake lights but a different light assembly. The fenders look the same so if you really want/need brake lights you could buy the switch make the wiring harness to have them.
Thanks JD Seller--that'll help me figure out why they are not working.
P.S. Do you know if the tractor would be wired for a rear work light--it doesn't have one. There is a 2 prong plug on top the trans at the right rear of the seat--comes out the wiring harness right where the harness goes through that fender. It's not hooked to anything. One wire is black and my test light shows it to be a ground. The other is blueish-green and doesn't turn hot with the light switch that I can tell. I'm pretty much finished getting everything working--even checked all the safety stuff and everything is working so I don't know what else that would be for.
Chris I think the rear work light was a field installed option. You got a short harness that hooked it into the tail light supply,IRC. It bolted to the top of the fender.
Thanks, I bet that's what the hole in the right fender just ahead of the tail light housing is for. I'm thinking the connector I found is the right one but I'll have to look more tomorrow.
Chris, I have a PDF of the Deere Tech manual for the x55 series, it has all the wiring along with the rest of the tractor.
If you would like it shoot me your email
Joe
