Quick Hitch
Texasmark1
Posted it here because it's more of a tractor thing than
implement; possibly could go under Using Your Tractor however.
Thought I did all the research and ordered a couple of quick
hitches for my Ford 30-40 hp tractors. Got it all ordered and
brain was still rolling.
Then comes the thought that the ones I ordered had a fixed 27
1/2 minimum pin-pin mounting dimension even though I
wanted the fixed frame to assist in hookup alignment as the
arms on the Fords just flop around without a stabilizer bar.
So I jump up and go out in the rain with my ruler and start
measuring........oops, only one fits the criteria.
So back I come into the house and call the co. and tell them of
my mistake. Guy said he got the order cancelled, but the charge
was still pending on my bank account as of yesterday evening.
However, it's a reputable company that I have dealt with for
years and they make good on their sales.
So, I ordered the other type, twice the price, more functional
however, that separately fit on each arm. This type has a
separate, adjustable arm that linked the two sides and that's
what I ordered.
The reason I posted this is a heads up for any of you that may be
in the market for an easier way to hook up old iron, and if you
are like me where one of your smaller tractors has had the arms
replaced with Cat II you need to remember that and just put
adapters on your Cat I arms.
Mark
You caught your problem in time...I didn't...I bought & installed, had to keep it. I then ended up buying set of Pat s quick hitches, liked 'em so much that I bought two more sets, for another tractor & my films' N. Once made 3 implement changes in 5 min. Cool!
Boy that was quick. The ones I settled on were Pat's also. Looking forward to using them. If I like them I will buy a set for the other tractor too; probably just a matter of time. However, for me, I have a couple of implements that are real heavy and just a bear to connect which I attach to the larger tractor. The smaller one gets light implements and they aren't too bad, but we'll see.
Mark
Pat's are a good product.
I've had a set for years.
Originally I used them on a Kubota that had those silly turnbuckle
things that you had to loosen to open the arms.
When I traded it, I put them on my home-brew
Farmall Fast-Hitch to 3-point conversion.
(arms on a fast-hitch do not spread open)
They work great.
If you use PTO stuff, check your shaft length.
Pat's only extend the arms a little, but you should check.
ps while you wait, grab one of those longer toplinks too.
most implements the standard will be fine, but when you want a radical angle, you'll need the longer one with a Pat's on.
I've owned both a quick hitch and Pat's Quick adapters. I like Pat's Quick adapters better because Pat's can be used on both Cat l & Cat ll implements with of course the correct bushings.
(quoted from post at 08:21:46 01/03/15) Posted it here because it's more of a tractor thing than
what I ordered.
Mark
I prefer to have a tractor for each implement :)
Oh sure! That REALLY simplifies things doesn't it!! :)
I like having 7 that run! That means that I have anywhere from 1-6 to get the other one (s) unstuck! :
Bryce
(quoted from post at 12:53:37 01/03/15) Oh sure! That REALLY simplifies things doesn't it!! :)
Bryce
Simple, get one for each implement and then get that extra big one you always wanted to get the others unstuck! That means I only need 10 more utility sized tractors, one about 50 HP 8 in the 100-125 HP range and then a Big Bud!
Rick
I've been lookin' at 'quick hitches' for years. Couldn't seem tp make my mind up about getting one or not.
Now, I'm kinda getting tired of forward and reverse or side to side to hook up an implement. Are they as handy as y'all say they are?
Greg
Here is a little trick that may solve some problems, buy a 3point drawbar, use some angle irons and bolt it to the implement, this may take a little engineering but it worked for me.
