Specifically this is on a JD620, but it shouldn't matter, it is a generic starter issue.
The starter spins but will not turn the flywheel. When looked at while parked the teeth of the starter and flywheel appear to engage normally. When trying to start it though...
The starter sounds like it works fine, but the bendix gear just spins really fast without turning the flywheel. When you let off the starter button, it grabs the flywheel as it slows down, but then doesn't have enough force to turn the flywheel. It doens't seem to matter where on the flywheel you are. I oiled the shaft on the starter to make it easier for the bendix gear to spin.
What to do? Need to use this tractor tomorrow.
