(quoted from post at 10:40:10 12/31/14) My truck gvw is 13200 my trailer is 12000 together that's a total of 25200lb under requirement for CDL. People are telling me that because my trailer is over #10001Lb I need a CDL. That's not the way I read the law! Am I right?
(quoted from post at 13:58:21 12/31/14) I have a CDL B so I'm not too concerned. It's the whole DOT number thing that I still don't know about. I went to the DOT website,filled out the questionnaire and it said not to go any farther,I didn't need one.
(quoted from post at 13:45:27 12/31/14) Ask 10 different troopers and you will get 10 different answers. We are running our own semi's here hauling our grain and equipment with no CDL's,, I would like to run my semi/drop deck to Rantual with all my toys, but I'm afraid I will get a scale guy that will make pull around back till it's sorted out,,,maybe miss the show,,seems if you have a goose neck and pick up they will not look so close,,,Darn shame we live in a country that has any kind of rulings like this to contend with...when we cross a state line it's near like going into another country...the CDL's and commercial license for trucks is mainly a tax/income situation, same with Highway fuel..
(quoted from post at 08:25:23 01/01/15) So I finally heard from a DOT officer last night who is a friend of a friend. He stated that if the truck and trailer combination weight does not exceed 26001 no matter what the gvw on the trailer is a class c is sufficient. A class A is needed if the GCVW is over 26001 and the trailer is over #10001. A truck that is under #26001 and tows a trailer under #10001 still does not need a CdL. The key is the trailer! If the trailer is over #10001 than combination weight comes in play. If the trailer is under #10001 trailer is irrelevant. I think the law needs to be rewritten so it's not so confusing. I drive from PA to NJ at times and have a DOT# and that's a story for another time. Thank you for all the feed back!
(quoted from post at 15:36:19 12/31/14) Every time this question comes up, there are a million different answers. Unfortunately most of them are wrong, and will result in you getting a ticket is your ever pulled over. Believe me, since I first started researching this mess back in the late 90's before buying my current service truck, I was so confused I didn't know what to do. After hours on the phone with guys at the weight stations, I finally reached "the horses mouth". He was the local DOT safety officer and the only one out of them all that would give me his name and direct line. He ended our conversation by telling me that if I ever had any trouble with any officers over what he told me, to call him and he'd set them straight as he was 'the horses mouth' and the one that told them what the law actually said, not just what they thought it meant. I've been stopped and weighed more than my share of times, had several, random, roadside stops for inspections, etc, and other than overweight tickets for my rear axel (something I know can happen if I'm stopped on the interstate), I have never had a problem with anything I've done because I'm within the regs on everything else.
In my case I've got a truck with a 26,000 GVW (de-rated down from 33,000 by a MFG sticker), but it weights 32,000 fully loaded. I keep it tagged for 38,000 and I often tow a trailer with a GVW of 10,000 lbs. Where I run into trouble is I typically have a touch over 20,000 on my rear axel. Even then this is OK on a back road, anything over 20,000 on each axel is considered overweight on the interstate.
Like I said, I've gone through this whole mess myself so I know where you are right now. Too watched an ex-buddy go through it on the far wrong side of things, and because he was too stupid to listen to me his wallet definitely for it. I've also seen several of my customers have to deal with some of the same issues and they eventually discovered the same things I did, and it usually cost them to do it.
Now there may be minor differences based on the state you live in, but in general this is what is required at the Federal level, and what we have to do here in NC.
That said, the GCVW doesn't matter one bit as far as a CDL is concerned. In other words you can have a truck with a GVW of 26,000 lbs (no CDL required), and pull a trailer with a GVW of 10,000 lbs (no CDL required), for a combined weight of 36,000 lbs, and still be perfectly legal. I do it all the time, and have never gotten a ticket because it's legal to so. As long as your tag covers the full weight of both the truck and the trailer/load, the combined weight means nothing beyond that.
Now if you take the same truck your driving with a class B CDL and put a trailer behind it with a GVW of 10,001 lbs or more, then you will have to upgrade to a class A to stay legal.
Now, if the GVW of the truck is over 10,000, and your planning to go out of your home state, then you've got to have a health card, regardless of whether you have a CDL or not. If you stay within your on state, then no health card is required.
If you've got a class B CDL, you can drive a single vehicle with a GVW of 26,0001 Lbs or more. That vehicle can also tow a trailer with a GVW of 10,000 lbs or less without any changes to the CDL.
Now when the GVW of the trailer goes to 10,001 lbs and over, you are required to have a class A CDL, regardless of what your towing it with.
In other words if you are towing a 14,000 GVW trailer with your dually, then you are required to have a class A CDL. In a case like this, the CDL will then have a Class8 restriction on it. This means that your A CDL covers only a pickup, or small truck, with the trailer, but doesn't cover you to drive a tractor trailer. On the other hand if you have an unrestricted class A CDL, then it will cover anything from a tractor trailer on down to the pickup with a trailer over 10,000 GVW.
If you have any more questions feel free to email me. If it's not something I already know about after nearly 15 years of dealing with this mess, then it will be something I really need to find out so it doesn't eventually bite me too.
(quoted from post at 17:09:29 01/01/15) I use the term elevated license because everybody seems to think that >26k automatically means a CDL and it doesn't. There are regular A, and B licenses just as there is also C CDLs as well. You can have Class A, B or C as a CDL or a non CDL. This concept seems to be lost on everybody.
If your Gross Combination Weight exceeds 26k, by either registration, rating or actual you better have an elevated license (something above a C).
The situation you quoted, either unit by theirself was ok, but in combination resulted in a GCWR in excess of 26k, so you're gonna have to have more in your hip pocket than an ordinary drivers license.
(quoted from post at 19:26:47 01/01/15) what I AM SAYING; the fmcsa dictates what is and is not commercial. not the owner or driver. Also; there are exemptions for some units. Where I live; RV; farm exempt; emergency equiptment operations (fire and such); require NOTHING. just a traditional operators license. there is no such thing as NON-commercial Commercial Drivers License.
