fixerupper
Drove a screw into the wall of the old shop to hang a broom on and there was a flash and pop and now the press doesn't run. Backed the screw back out to find the tip melted off. Should have known better and screwed a 24" long board into the nailers and then put the broom screws into that board at the desired height. The shop was built in 82 and I used 3/4 Blandex or chip board or whatever the new name for it is, for the inside walls. Wood was cheaper than steel so wood is the way I went. Never again. The good part is I can cut a hole in the wall there to get at the damaged wire and install a box to do the splice in without worrying about cosmetics much. The new truck shop has steel interior walls with all wires running in conduit so this kind of a stunt won't happen again. Jim
