john in la
U-Joint give out in a SIL pickup. Drive shaft hit fuel tank denting it and causing a very slow leak. It is so slow it does not drip as the gasoline is evaporation before enough leaks to form a drip; but tank is now damp and you can definitely smell the gas in the air.
Anything I can apply to the outside of tank that may stop this leak.
I am about to go outside and wipe the tank down; blow it off with compressed air to dry it and find the leaking spot.
