Can't Afford Tires? CL Has The Solution!!
Bryce Frazier
Can't afford tires?
Can't get field work done because of this?
Looking for a cheap, effective solution?
Need an answer now?
Well then Craigs List has the answer for you!
INTRODUCING:
"Weld On Tires"
Hay Rake
Either Amish/ etc deal, or they priced those style tires and after picking themselves off the floor from the shock, came up with a cheaper option.
(Edit - I see rubber on the rear, so not a religious deal, strictly $$$$$ I guess.)
Actually, for as immobile as those rakes are (you won't haul them down the road behind a pickup for long, local on farm use only with those caster wheels!) I kinda like that, traction with the gaps, no flat no maintenance, I like it. Could weld a little rebar on for treads if more traction needed.
Paul
(quoted from post at 11:34:50 12/08/14) Can't afford tires?
Need an answer now?
INTRODUCING:
"Weld On Tires"
Hay Rake
Probably can't find nor afford them if they did...I had a neighbor that wanted to give me one of those but the tires were full of mouse holes. I can't remember the size, but as I recall they were an odd size. It probably just slid the tires when they tried to use it..it at least needs some cleats welded to the tubing.
