I have an Onan 12.0 DJC generator wired through a 200 amp transfer switch to provide backup power to my house. I start it about once a month to keep the battery charged. Sometimes when I switch to generator power, it is only producing a partial voltage. This usually happens if there is only a small electrical load (lights etc) in the house at the time. If I turn on my heat pump, the generator grunts and the voltage comes up and it works fine. It holds very close to 240/120 volts and responds well to changes in load. Would a new voltage regulator board fix this problem? Thanks for your help and advice.
