37chief
- Location
- California
Last week I changed the oil in the wife's car. It was down almost 2 qts. The car has never used oil. The problem was a leaking drain plug rubber gasket. I doubt the wife couldn't even open the hood. I think it is time for a little check the oil school. I dropped the ball on that one. That would never happen to my tractors, I check them every time they go out. I have the grand daughter trained on checking the oil in her car, even adding if needed. Remember when you got gas, and sat in your car, and the attendant came out put in gas, checked the oil, and cleaned the front window. There is a town where I live. Rancho Santa Fe, Ca. that still does that. if you pull up in a Caddy, MBZ, or a Rolls. Stan
