JD 2010 hydraulic filter
I have a JD 2010 gas. I replaced the hydraulic filter some years back. It is a fine mesh screen, not a throw away. I pulled it recently, and the rubber gasket that is glued on to one end was loose and had expanded too big as well. What do you recommend for a new gasket and what type of glue would I use? The body is brass.
Anything like that that I have ever seen had the rubber or plastic end MOLDED onto the screen, not glued.
