Puma 155 plowing wet clay
Nice plowing job - looks like you got a good crop of sea gulls going there. I'm always amazed how they find plowed ground so quickly.
None of my business, but your plow is running downhill.
Lift the hitch a little and those "rows" will disappear. Promise. :>)
Allan
It is amazing to see how farming gets done around the country and the world from the people who post here. In my part of the country (SW Ohio) you would not dare to plow ground as wet as that appears, Unless you want to try to work up rock hard clods that wont break up when it dries. Still nice to see ground being plowed up for crops. Bandit
(quoted from post at 05:59:30 11/13/14) None of my business, but your plow is running downhill.
Allan
The native rock here is Slate, hence the dark colour of the clay soil. There is only 4"-5" of top soil on this farm over the Slate bed rock.
This Puma is running on 600/65R32 rear tyres, and the outer edge of the rear tyre is crushing down the edge of the last furrow . At this shallow depth there is not enough soil depth to gather up enough soil with the leading body to throw & fill the extra wide open furrow even with the plow is set at its widest 18" furrow width.
What we call clay does seem to vary around the country. One thing it all has in common - when its dry its like concrete.
Yeah and it looks more like sandy loam to me. My Houston Black
wouldn't respond nearly as responsible and would be all gummed
up on the plow shares which is why you have to use rolling stock
here and moldboards are useless.
However, really nice job and helps to have enough HP to be able to
pull enough bottoms to get the job done in a timely manner.
Mark
(quoted from post at 09:36:37 11/13/14) Wizzo were in the UK is that tractor working as it is not the wet clay we get here in Nottinghamshire. MJ.
Google Maps - SA42 - North Pembrokeshire
Click on EARTH to view the area as photograph.
You can move left & right and up & down, and + & - to enlarge the view of the area as photograph.
Makes a big difference what time of the year. In the fall the ground has all winter to freeze and thaw and mellow.
Or some of what we had in S. Yorkshire.... you could literally make bricks with that! We had one particular field that the according to my elders, the previous owner (he must have been an idiot) during the last war had hired a Fowler Gyrotiller run over it and it brought all the clay subsoil ( and several huge boulders) up to the top. It took many a year and hundreds of loads of farm yard manure to get that field back into good condition again!
What is this Limey on about?
