Kinda OT Grain Dryer Electrical Question
super99
My drying bin has a Shivvers recirculator drying system in it.I don't have it set up to transfer to another bin, I just pull the dry corn off the floor and dump it on top of the wet grain when drying. The thermostat that controls the auger on the floor of the bin quit working( 40* years old). I'm looking on Amazon for another, Mine is a Honeywell Type T675A, R-B opens on temp, R-W closes increase. All the ones listed have more numbers behind T675A. I found a listing for T675F Crop-trol controller. It doesn't have much of a description listed. Will this work for me or do I keep looking?
Thanks, that helps explain it a little better. The T675A1540 has a 3.6-12F range. The T675A1458 is a 1 F Fixed. Any idea which would be best to use?? Thanks, Chris
I believe the T675A1458 with 1 degf fixed is too tight and would start/stop the motor too often.
I would use the T675A1540 or the T675A1425 depending on length needed and adjust the range to get the control you need.
What is the range set at on the one you have now?
also take the cover off of your existing T675A to check for the full set of numbers. also see where the adjustment is set on yours now.
I have the controller off and in my hand. Upon closer examination, it has 1458 stamped inside on the side of the controller. I see no adjustments anywhere. Thanks for the help, Chris
