Tractor virgin
my ignition switch recently failed and I replaced it with an after market switch. I originally thought it only had the two positiions and when wired to start I had to click it back to the first position to disengage the starter. A friend of mine used the tractor not knowing and as you can guess ate up the starter. The starter has been replaced and I also found out the ignition switch does have a spring back to disengage the starter and I have rewired it but the tractor still does not start. I can jump the solonoid and it cranks so I assume I'm not completing the start circuit. I'm hoping there is a fuse somewhere but haven't looked yet, can anyone help with that answer. It's a 1977 Ford 3600 diesel, thanks.
