Will 92 Bonneville right side door fit my 98?
SDE
I swapped the doors last night. The inter door panels are different, but I got it on ok. At 45 mph it starts to leak air around the top of the door. When I tried to make an adjustment, I noticed that the door looks to be too big for the opening. Is this a "Close but no cigar" type of situation? I would rather put the original door back on, than to listen to the wind noise. But if is suppose to be able to fit, I will try more adjusting.
Thank you
SDE
If the door appears to actually be the same but is out at the top, block the door open and pull the top frame in (by hand with steady force) keep "adjusting" till the noise stops. A sheet of printer paper should be held in the gasket at all points. Jim
Thank you. I had thought about doing that very thing, but it is the front and rear edges that appear to be to close to the other panels.
SDE
