Dave H (MI)
CGID
Thanks for the info on your nut trees. If you don't mind, I'll bug you next year and see how things are.
You can try, but don't forget...I don't live there and the closest tree to the road is probably 7-800 feet across a muddy field. It is not a situation where I can go out and check each morning and i don't spend the time on the property that I used to. Last year was kind of a fluke as I was building a stone BBQ in the center of the property so I happened to be there in a year when the nut crop was huge. That was the first time I ever ate one. I will grant you, they are tasty, but I don't get a lot of opportunity to get them before the wildlife.
