I need some help Does any one know how the front mounted pump shaft for a Massey 3165 comes apart at the crankshaft?
[The fan belt is worn out/fell apart]
It’s the front hydraulic pump shaft set up used for a 200 MF loader.
My shaft has 4 bolts that connect a plate to the front crankshaft pulley then the shaft that is about 15” long goes into the front mounted hyd pump.
I can not get the shaft loose at the mounting plate at the crank pulley. I thought it was splinned but the picture in the model 200 MF loader manual appears to be threaded. I have tried with NO luck of getting it apart.
So does anyone know which way you need to turn this thing to get it loose?
I’ve tried going both directions. There’s NO room to get a good grip on the shaft.
So My hope is I can get a little more aggressive if I know the proper way to turn the shaft
