If it is a P-400A, the operators manual states SAE 90w gear lub normal and SAE 120w gear lub in hot climates
Thanks, its a P-2000, but should be the same. The one page missing from my book is the one with the oil spec on it...
I have a model 300 I am assuming it uses 90 weight also does anyone know how much it holds? Also there are two tubes coming out the front I'm assuming the bottom is to drain it the top one is the Max fill height?
