It's always said if you can run an electric device on 220v it's cheaper or you're better off doing so than running on 110v.
How is this because when using the electrical formula the watts still come out to be the same?
When you double the voltage the amperage is cut in half. I just thru these numbers out there in the formula as an example.
Volts x Amps = Watts
110 x 14 = 1540
220 x 7 = 1540
What am I over looking?
110 x 14 = 1540
220 x 7 = 1540
