Starter removal MF 231S
RogerD50
New User
Trying to remove starter from 231s tractor and can't get third bolt out. There is no room to get to it. Does it take a special tool?
Hi
Most of those Massey starters are a pain to
undo that third bolt. its kinda tucked in the
back right up against the block. all the ones I
have ever done. I have used a 3/8 drive shallow
socket of the correct size 9/16 comes to mind not done one in a couple years, a universal/swivel drive adapter, and enough
extensions to get past the motor end of the
starter. then undo with a ratchet and hope
the bolt does come undone!. a guy might be able to
use an obstruction wrench but don't have one so
never tried it. my sockets method has always
worked. have seen a few tractors with 2 bolts
holding the starter and the 3rd never put back
L.O.L.
Hope that helps a little.
Regards Robert
I'm not really familiar with the Massey's... but on the FOrd's that use that starter, I use a 3/8 drive 9/16" socket, a couple of wobble extensions and a long handled flex head ratchet. The wobble extensions allow you to get around the shoulder of the starter. Much better than a universal joint...
Rod
