(quoted from post at 15:25:34 09/22/14) Whoa, not that simple. With simple Tees the oil in this open center system will just freeflow through the loader valve and deliver NO pressure to your splitter valve. You need to install a diverter valve into your supply line to the loader valve, and then Tee back into the return line. and then switch between the two functions as needed. This still doesn't give you a hyd circuit to raise and lower your dump trailer.
Your best bet would be to see if your loader valve has power beyond abilitys. Then attach another valve, hoses and couplings to feed the splitter valve and your dump trailer. If your loader valve doesn't have power beyond capabilities you can supply a secondary valve with the previously mentened diverter valve. Be sure you plumb the new circuit with an unrestricted return line back to sump,so that you don't ruin your pump.
Loren, the Acg.
(quoted from post at 11:38:21 09/22/14) Just tee off from the two hoses that feed your
loader control valve and from the "T" fittings run
two hoses to the back of your tractor to the
control valve for the splitter. quite simple
actually.
Good question, my wife just bought the trailer, (because it was a good deal), I dont know anything about the trailer, and this is why im looking into adding a port to the back so i could control it, I will check and that is a great thing to research before i try to use it.(quoted from post at 17:30:48 09/22/14) Loren has you pretty well covered but one other thing is how much oil does the cylinder on the trailer hold and does the tractor hydraulic reservoir hold more than that. Is the dump trailer power up and power down or gravity down? DOES IT HAVE ITS OWN CONTROL VALVE?
actually.
(quoted from post at 12:25:34 09/22/14) Whoa, not that simple. With simple Tees the oil in this open center system will just freeflow through the loader valve and deliver NO pressure to your splitter valve. You need to install a diverter valve into your supply line to the loader valve, and then Tee back into the return line. and then switch between the two functions as needed. This still doesn't give you a hyd circuit to raise and lower your dump trailer.
Loren, the Acg.
Everything everyone as said has been great. And as you can figure out I dont have hardly any experience in hydraulics, just curious, could I put a shut off valve just after either side of a standard T, to shut off that circuit, just curious?(quoted from post at 19:21:06 09/22/14) Yes, you need to direct the oil to the secind valve that you install, or it willsimply flow through you loader valve. As I stated before and Old said, you can series in another valve after your loader valve if it has power beyond capabilities.
Loren
