JD148 loader swap
mb58
I want to take my JD148 loader off of my 4020 (roll guard) tractor and put it on my 4230(cab)tractor. How do I plug in my hydraulics since the 4020 has two hoses coming from the valve body to the SCV which is controlled by two levers, but the 4230 will have to be controlled off the levers inside the cab. Do you add two more hoses and plug in to both SCV's or do they make some kind of splitter?
This photo is using tractor remotes to control loader
You could install a cable operated ind valve which would not tie up rear remotes.
You could install a PBY aka auxiliary outlet(parts key 4)
