hydraulic pumps
Is there a company/place that rebuilds Ag tractor hydraulic pumps? The prices for a new pump from Kubota is rather pricy... I seem to have bad luck with pumps..had to replace one on a Deere a few years back...ouch!!. I live near Albany NY. ..Thanks
In many situations, by the time a hydraulic
pump needs rebuilding, it is not cost effective
to do so. Parts cost a lot, in comparison to a new
pump,and, do you have the special tools, such as a
surface grinder to reface wear plates,(Which may
then need to be heat treated). Most manufacturers don"t want to sell spare parts. Can you rebore the
piston pump bores ? And, who sells oversize pistons !
As a KUBOTA dealer for 28 years , let me say I have tried rebuilding in house and tried sending them out to other shops. MOST of the time by the time you put the new parts needed and labor you are 60 to 70 percent of cost of new pump. Then we found most times rebuilds came back sooner or latter and most times sooner. Just got to where you have to really beg me to rebuild your pump. If you plan on keeping the unit replacement is the only way to go now if you just want to patch it up to get it thru a sale might reseal the pump.
