When running my workmaster 641 tractor and clutch is pushed down the tractor gear pushes you forward.
In the past I could press the clutch and the tractor would not move andthen I could shift gears.
I turned the clutch pedal adjustment did not help.
Is it possible my clutch disc is stuck closed?
Is there a way to unstick it without takeing the tractor apart?
So what is involved in fixing the clutch? I do have some mechanical abilities.
Thanks you for your help
All comments welcome
