Hello everyone, I have a 4430 JD that recently stopped shifting when I slide the lever sideways either from one to two or three to four. It is a quad range transmission and after I got back to the yard I drained the Hyd fluid and checked the sump screen and Hyd filter. Both were quite clean with not much debris. In the oil there was a few pieces of what looks like flakes from a clutch and three years ago I had them done at a reputable local JD dealer and I know at that time nothing was flushed out so I"m hoping those pieces were still from that episode. Any advise or suggestions as to what the problem is and how I can fix it would be appreciated! Thank you
