My dang 400 has sat at the Iowa
fairgrounds since Tuesday, and today it
wouldn't start! It had been rained on
Wednesday and Thursday, so maybe that's
why it won't start. I had the exhaust
covered too. I believe it is getting fuel
because it drips from the carb after I try
to start it. As the motor is cranking a
fine white mist seems to come from the
muffler (unburnt fuel?).I've checked the
firing order, checked for moisture in the
distributor cap and plug wires, and I ran
a dollar bill through the points. My
battery is one crank away from dead....
Could it just be moisture somewhere in the
electrical system? Condenser? It has a 12
volt conversion kit. Would water on the
resistor be causing a problem? I have to
have it running by around 9 AM for FFA
judging. Thank you
judging. Thank you
