jon f mn
My combine has a Chrysler 318 engine and it runs
like crap. It's been sitting for several years so
I'm sure that's what the cause is, but where to
start. It coughs and backfires through the carb
when you give it gas and under load. Under load it
will only run with the choke fully pulled. It's
not the float tho because I had to replace that
and I adjusted that. Is that more likely a carb
issue or ignition? Also it has a vacuum chamber on
the side of the distributor, but it's not hooked
up. It has a factory plug where the hose should
hook to. Doesn't that need to be hooked up? I'm
wondering if someone replaced the distributor and
never completed the hookup.
