I bought a Woods Zero Turn last saturday with a 52
inch cut and a Kohler 18hp Command Engine. One
cylinder has 155 psi of compression and the other
cylinder has 135 psi. If I squirt a little oil in
the lower one it comes up to 155 psi. Do you think
this difference is much to be concerned about? I'm
thinking I may pull the head off and see why it
has lower compression.
The man I bought it from said it started
running on one cylinder and he took it to a shop
and they said the engine was totaled. For some
reason they even took the flywheel off and found
it only had 3 magnets in it for the charging
system. He said he always put a trickle charger on
it. They also told him some one had it apart once
before. The hour meter has 856 on it.
