Duetz fuel probls
tractor guy I have a duetz D6006 and when I make 2or3 passes bush hogging it starts to put out alot of black smoke like its over flowing with fuel I took the pump apart a few weeks ago and the spring a float were laying to the side I put it back they its supposed to be...Could I need a new fuel pump
You would be more likely to get help if you tell what it has for a pump since the Deutz is not common. I have experienced heavy black smoke and blubbering due to fuel starvation. The fuel line was 90% blocked.
(quoted from post at 11:43:15 07/04/14) Its clear it only smoke when I idol up high when just sittin still it doesn't smoke
That's exactly how mine was. It would idle or run at low RPMs all day.
(quoted from post at 14:33:28 07/04/14) What did you do
I checked fuel flow to pump until I found the point where it wasn't getting through, then cleaned all the crud out.
I helped a guy take a birds nest out of the air intake. It was up against the aspirator. This was before the filters.
It's been a while but as I remember it would pull a little and then put up the blackest smoke I've seen. I think that was a 1370 case.
RT (my 2 cents)
