Another Tire Question
UP Oliver
I have a JD 336 baler. My 11L - 14 tire on the left side is shot, won't hole air. I have a tire off an old Oliver baler that is a 9.5L - 15. Can I put that on in place of the 11L - 14? I have about 1000 bales to do the next week here or so. I have a broke down 1994 F150 here in my yard with real nice tires on it that look like they would fit. Actually one of the front tires off my Oliver 1755 looks like it would fit also.
Any help is appreciated.
Neither the hay nor the baler will care. I used to have one that sat a little crooked due to an improper tire. The only important consideration is that you need a lot more tire on the left than right if you have moisture in the ground. If it is too narrow it will cut in.
I have a 11L14 tire on a haybine much like yours.
I got a 9.5L 14 about same condition with hardly any tread left. I used sawzall to cut the bead out at a angle and then cut tire 90 degrees from bead so ends would overlap. Tapered the overlap ends and installed a tube. 9.5 is about a perfect fit for 11L14 .
