Larry Metzgar
Back to basics I guess. I pull all the plugs from the cyclinders. Turn the motor over till I have compression on number 1 cyclindr. Should I not now have spark at or near the same time? I continue the process feeling for compression and looking to see if I have spark at the plug. If this is correct the first wire coming out of the cap was not where I was told it should be. I change all the wires to the plugs and now it backfires through the air intake of the carb. Am I on the right track as far as finding the starting point for number one cyclinder and plug wire cap sequence? Thanks.
