JD 70 Hand clutch
Hay Guy 257
New User
I have an old JD 70 that I use a lot for raking hay but I am in a bind because the clutch isn't working, it stays engaged all the time. I start it and stop it with the foot brakes. I start it with the brakes applied, in gear and the clutch disengaged. It starts moving as the starter is engaging, I hope someone can tell me what the problem might be. It also seems to leak oil between the drum and the engine body.
More than 1 thing wrong. That said, start with making sure the pulley brake is adjusted properly. It is integral with the clutch linkage. HTH
Take off the pulley cover and look...I think a clutch dog may be broken and jammed up.Had a 730 that did that once.Or a disk has come apart/disentgrated and wedged in there. Those clutches are REAL EASY to work on...
"a disk has come apart/disentgrated and wedged in there"
That"s definitely the MOST likely scenario.
Open up the operators manual and perform a total clutch inspection and service as described and illustrated. Before you have a wreck.
Check the bolts that adjust the clutch, they will wear a grove in and catch on that grove, at least that was the way the AR did.
(quoted from post at 22:10:40 06/27/14) I have an old JD 70 that I use a lot for raking hay but I am in a bind because the clutch isn't working, it stays engaged all the time. I start it and stop it with the foot brakes. I start it with the brakes applied, in gear and the clutch disengaged. It starts moving as the starter is engaging, I hope someone can tell me what the problem might be. It also seems to leak oil between the drum and the engine body.
Have you been leaving it in running gear with the clutch disengaged?
