Another 806 pto question
jdv
Was putting the new clutches in the pto, and the old one had 5 well used fiber discs and ten metal discs, two metal discs between each fiber disc. In the new ones I got there are 7 fiber discs, and 9 metal discs, so where do I go from here? I don't have a book on this as I assumed it would be a simple out with old in with the new. Any help would be greatly appreciated. As it stands now I put one metal disc to start and alternated until I had all of the discs in place. I ended with two metal discs together on the outside though.
That is the way I do it though it doesn't make as much difference whether you start with on or two steel on the 806. The plate under the outer snap ring is a solid spacer. The newer PTO units have a stamped steel plate that is quite a bit thinner so on those I always put the extra steel disk next to it.
