Lp regulator
gj445
New User
The regulator on my 445lp seems to have gone bad. When you turn on the vapor valve, you can hear gas going through the air cleaner. Any thoughts?
Likely the diaphragm for the High side regulator
in your convertor has got a leak. This allows
high pressure fuel to the low side regulator and
the low side valve can't hold it back.
I have gotten a rebuild kit for ensign in the past
but need to go looking for the contact info. Last
kit I got was something like $75 and that was
probably 10 years ago.
jt
(quoted from post at 09:08:00 06/15/14) Likely the diaphragm for the High side regulator
jt
That sounds right. Many thanks, jt.
