Hydraulic fluid for Case 300 special
Tim Girling
New User
Hello,
I was using my fathers old Case 300 special tractor to do some renovating on my house when the rear axle seal started leaking. I replaced the seals, but I'm unsure of what hydraulic fluid I need to use for the hydraulic pump and gear box?
Thanks,
Tim.
for hyd use a good hyd oil cnh Hy-Tran is what I prefer but a aftermarket oil meeting cnh specs will work will work as well, the trans/rear axle uses 80/90wt
cnt
