I have an industrial tractor called a DO MOR, j d seller posted a pic of one like mine some time ago.
It is a componet tractor--Det.engine Napco heavy axles etc.
It has front wheel steer---all wheel steer and a position where all 4 wheels go sideways. The steering is controlled by a 3 way hyd. block to select the steering position.
I like to use it in 4 wheel steer---The PROBLEM---After using it for a day in 4 wheel steer the next time I start it up it will be in that crazy sideways mode with the rear wheels going sideways and the fronts trying to work somewhat normal.
I have to put the selector block in the sideways position -get the wheels straight then flip into 4 wheel steer----Sometimes it takes many times to get it working correctly.
I understand probably none of you are famaliar with a DO MOR , but hoping some might be able to explain the hydraulics. Thank you
