Robert Thompson
New User
I am looking for the front rockshaft plates/bearings for an IHC A-144 cultivator to use on my 1946 Farmall A. I have all the parts except the left rockshaft plate/bearing for the front cultivators. I do have the right plate, but I would like to find a full set (both left and right) if I can. The part number is 30422B - right and 30421B - left.
Does anyone know where I can get these, or at a minimum, just the left bracket? It appears that I can probably have a new plate fabricated but I would have to find a new bearing. And does it have to be an actual bearing, or would a bushing suffice since it really isn't needed for a continually moving part? It only will rotate when I lift it at the end of each row. Seems to me maybe it should actually be a bushing...
The one I have (right side) is damaged so if there was a bearing in it, it is no longer there.
Thanks
Thanks
