I just put on a governor and the tractor starts up but I can't get the
idle right. I set the main needle out one turn from the seated
position and the idle mixture adjustment needle out one turn open.
I starts, runs then will die. When it starts, the RPM's are pretty high
but the governor will level it out to a point. Is there a standard
setting for the idle speed adjustment screw that is hooked to the
governor? The adjustments that I have made have caused either a
very high RPM or not start at all. If anyone can help me out, it
would be greatly appreciated
