Oliver 1650 Hydraulic Issue
RichC
New User
My hydraulic cylinders settle as I am using different equipment. Are there any external adjustments I can make?
Thanks
(quoted from post at 21:02:50 05/27/14) No. Agco sells a kit to re-oring the valves under the seat. Are you sure its the tractor and not the machinery?
Josh
Thanks for the reply. Its the tractor as the loader does not settle when unhooked. Anyone done one of these? How major of a job?
Never rebuilt the valves,but I've been in to them a lot deeper than that several times. The valve would be about the easiest job you could do as far as hydraulics go on those. Take off the seat,then I think there are something like 13 bolts around the outside and lift the cover off. Get new O-rings for those tubes between the cover and housing while you're at it.
(quoted from post at 02:39:49 05/29/14) Never rebuilt the valves,but I've been in to them a lot deeper than that several times. The valve would be about the easiest job you could do as far as hydraulics go on those. Take off the seat,then I think there are something like 13 bolts around the outside and lift the cover off. Get new O-rings for those tubes between the cover and housing while you're at it.
Thanks for all the replies. Think I will tackle it later.
