4320 John Deere
richardhh
New User
I have a 1979 model 4320 john Deere and just stared it up for the first time this year and noticed that the oil was full of diesel. could this be an injector problem? what should I check first?
First suspect would be fuel lift pump, followed by fuel injection pump shaft seals.
Common problem, if not the lift pump there is a seal on the back of the injector pump I believe it can be put in without teardown of the pump,not sure.
(quoted from post at 11:24:46 05/16/14) I have a 1979 model 4320 john Deere and just stared it up for the first time this year and noticed that the oil was full of diesel. could this be an injector problem? what should I check first?
Your tractor if a '79 model must be a 4230 not a 4320 but the remedy for fuel in engine oil is the same
Jim, as you probably know a 1979 model Waterloo tractor would be a 40 series, not a 30. Likely his date is wrong. Mike
(quoted from post at 13:40:31 05/16/14) Jim, as you probably know a 1979 model Waterloo tractor would be a 40 series, not a 30. Likely his date is wrong. Mike
Mike
Thanks for correcting my mistake. Danged OLDTIMER'S, what was I thinking?????????
richardhh, I will bet it is the (fuel pump) on the side of the block. A neighbor of mine has had the same problem with his 3020 when it sets for an extended period of time. The fuel pump just starts weeping Dsl through the seal into the engine oil! It is the most likely place it came from.
If the fuel in the tank is Higher that the fuel pump, Dsl will leak Dsl into the oil. If it is Lower that the pump, Dsl will not leak through!!!
Also look under the tank where the fuel line stub's into the tank there should be a Cut-Off Valve there, close the valve and it solves the problem when the tractor has to sit for an extended period of time! Hope this helps.
Later,
John A.
Hope this helps.
Bob is exactly right. I've rebuilt A LOT of them injection pumps and that's what happens. Most likely it's the transfer pump but it's possibly the shaft seals on the injection pump. There are no seals in the back of the pump that could cause this issue, but Garrett was correct that the pump doesn't have to be disassembled to replace the seals.
