FRONT END LOADER AND ROCK RAKE.
Geo-TH,In
Has any one removed the bucket from FEL and connected a 3 pt rock rake? If so, please post a pic.
Thanks
George
George no pic but I have a 3pt rock rake with a hollow main tube I stick my fel bale spear in main tube and chain it to the bale spear frame work s great
My tube isn't hollow. I only have one tractor with 3 pt, Jubilee. Sometimes I need to use loader to fix a drive, then it would be nice to use rake without trucking the Jubilee to that location.
It's nice to see someone else thinks the way I do.
Looks like I may have to invent a 3 pt adaptor to FEL. Thanks
George
(quoted from post at 03:20:02 05/16/14) My tube isn't hollow. I only have one tractor with 3 pt, Jubilee. Sometimes I need to use loader to fix a drive, then it would be nice to use rake without trucking the Jubilee to that location.
George
heavy rated trailer tie down D-rings work good for the pins.
bolt/weld em in, flip em up over the implement pins, couple big thick washers and then the lynch pin.
(D-rings inside a loader bucket also are a good place to hook a lift chain without welding hooks on the top edge....which will bend the bucket anyway.)
(quoted from post at 14:02:51 05/15/14) Has any one removed the bucket from FEL and connected a 3 pt rock rake? If so, please post a pic.
Thanks
George
I bought this adaptor for my skidloader....cheaper than I could build it. I can attach almost any 3pt piece of equipment. Skidloader is nice because you can see what you are doing and hydrostatic drive is handy for raking.
